Hello Oliver,
Do you think it's possible to have a 0.5 sec interval in timelapse mode (no auto ramping)? The minimum interval I can set in my 5d4 is one second thru the interval intervalometer. I wonder if UNLEASHED can overcome this camera limit.
I had several moonrise time lapses with a large zoom lens with 1 sec interval and a total of only 4 mins duration. I have to slow it down dramatically in post process to get a longer clip, but the slowdown introduces a lot of jerky motions. If I was able to set the interval to 0.5 sec, I believe the quality will be much better.
Zoom
0.5 sec interval timelapse?
Did a little research.
LRTimelapse Pro 2.5 has the intervals from 0.3 secs* – 120 min
*) For cameras which do not require the AF signal to be sent before the shutter release.
"By default the minimum shutter time will be calculated as (Shutter_Release_Time + AF_Time + 50ms) rounded up to the next 100ms. By default it’s 0.4 secs. "
It seems 0.5 sec interval is possible.
