Separation between listing Unleasheds with different (running) modes
Posted: August 14th, 2020, 7:12 pm
Small suggestion here: is it possible to separate each Unleashed so that the current mode in which the Unleashed/camera is operating is actually being met in the UI/UX?
Thus you can select in the main/start screen: show me all Unleasheds set in mode VIDEO (or TIMELAPSE, PHOTO, AUTORAMPING, ALL), and then the main/start screen only shows you ONLY those Unleasheds/camera's.
Let me explain: while one Unleashed (A) is doing a timelapse, another Unleashed (B) is doing a video recording and another Unleashed (C) is doing nothing (idle).
When you switch between modes: Photo, Video, Timelapse, Autoramping, you should get a list of all Unleasheds available for THAT specific mode, because the other Unleasheds are not available for THAT mode, due to already running in a different mode, which is not completed.
In more techinal terms speaking: IF unleashedScreen.isInMode("photo") AND unleashed("A").isRunningInMode("video") THEN unleashedScreen("photo").doNotDisplayUnleashed("A");
I think it is more useful to display the mode in which the Unleashed is currently operating in the overview of ALL the Unleasheds (begin/start screen) but that it is of no use to display THAT specific Unleashed in the other screens as well when it is still running in that other mode (e.g. video mode). Why list a running Unleashed in video mode in the timemapse mode also, it's of no use because you can't do a timelapse and shooting a video at once?
See attached screenshots.
I think you should have one overview screen for all (OVERVIEW) Unleasheds (so you can see what each Unleashed is doing at the moment), and specifc screens per Unleashed MODE (the side menu you pull from left to right). That would make more sense to me.
Then you see, when you start the App: which Unleashed is doing what at the moment?
Unleashed A: running timelapse
Unleashed B: running video
Unleashed C: idle
So the menu you pull from left to right only comes into the picture when you are in a specific Unleashed, and then you can pick in which mode you want that Unleashed to be operating.
Now it is designed this way: pull the menu from left to right in the start screen, select timelapse from the menu item, and ALL Unleasheds are displayed (even the ones occupied by running video recordings) but are disabled from operating them.
I think that Unleasheds already running in a different mode should be excluded from a list that displays a different mode. Only the beginscreen should display all Unleasheds, so that they can be set to a specific mode or be released from a specific mode. Then the UI/UX is more "to the point": when you want to control camera's for photo shooting, you only have those camera's in which you set the Unleasheds in photo mode. And the Unleashed set in other modes are NOT listed in that screen! It's like shifting M&M's: the red by the red, the blue by the blue, the green by the green. Setting an Unleashed in a specific mode also means protection by accidently messing with a current timelapse. If you have set the start/begin screen to only show Unleasheds that are set in video mode, you would see timelapse Unleasheds in that screen.
But as always: just my observations and suggestions.
Unleashed C: idle
