Tracking GPS errors
Posted: August 28th, 2021, 10:54 pm
[edit: this post was split from here: viewtopic.php?f=18&t=1060 ]
This is maybe an good example for in the firmware of the Unleashed to build in some sort of functionality to keep track of disturbances in GPS reception, either from the smartphone or an external GPS device (Unleashed accessory). Why? Simple: so that you can trace back with the Unleashed App which periods of time the Unleashed didn't had a valid GPS data reception. You can of course see that in the photos not having any GPS data, but while in the field, you must know over what period of time the GPS reception was missing.
Especially with Unleashed accessories is it highly recommended to have a possibility to see in the App what went wrong with that accessory, like no BT connection or no GPS fix, etc.
Now the user isn't able to track back the root cause of the error in the Unleashed and at what moment in time it started and ended. Example: you now have to go through all the photo's in the camera to trace back when the GPS fix dropped and when it was fixed again. That can be 1 photo, or 1.000 photos!
Of course an audible warning on the smartphone could prevent the user from having a 1.000 photo's not receiving a geotag, if the smartphone is connected to the Unleashed. When it is not connected to the Unleashed you want the Unleashed to give some data to the smartphone when it is connected and reports the failures, like a modern car nowadays has a board computer telling you how fast the car drove and what the oil-level was all that time.
Maybe a good feature to implement. I don't mean logging, I mean visual feedback for the user in the App. Also a good way for the user on the forum to let the team know what went wrong for how long, to determine if it is a bug or not.
